Are you sure this will work? Does it keep working in the longer run? It might be so that the Vado software detects a mismatch between the number of accu load cycles and miles driven.
It's been working since January and it'll keep working for 10k+ km. Software doesn't detect anything. If you're too worried about the mismatch between the charge cycles and distance driven, you can order a dual planet configuration that has half the ratio but will still increase your assistance speed limit by a factor of 1,675.
I plan to buy next summer. I hope you will still be around!
How much speed can you achieve on flat tarmac now?Just installed my Planet3 ring and wow
45 km/h is possible. Cruisespeed 38 km/h
You can use the range calculator on Specialized’s US site. It works for speeds over 32 km/h.The air resistance kills the battery range at high speeds, that's it. The Specialized Turbo Range Calculator is good for nothing as it will not accept anything more for average speed as 25 km/h in Metric or 20 mph in Imperial units - which is stupid as e.g. speed models of Turbo Vado can ride up to 45 km/h or 28 mph.
Well, tried it this morningride from home to work, being 12 km. Started of with 88% batterycharge and arrived with 53% left. 35% charge used. So, that would make a range of about 36 km. And a little headwind today. And you must take into account that this is a 250 Watt motor and a 500 kWh battery. I have the new TDC-W display installed.
(Wenn I put the bike in assistance-mode 1 that will give about 100 km range with an average speed of 22 km/h.)
I donnot reach speeds above 50 km/h on this bike with full assistance, unless there is a firm tailwind. (maybe age and condition come into play here)
Interested to hear your results @Balinus. Low winter temperatures degrade the range even further....This is encouraging for my planned use case (32km with a planned 32km/h avg speed).
