William - Bosch Team
Hi All,
Unfortunately, I doubt that Bosch will make the battery reserve configurable, and I personally hope that we do not. I realize that my opinion on this won't be popular, but keep in mind that Bosch designed it the way they did for a reason, and it is in Bosch's best interest to offer as much capacity as they safely can.
[Edited to add this: Bosch is required by at least one regulation to have the 2-hours of light power.]
That being said, the buffer when not using lights or eShift is actually very small. It's just enough to keep you out of trouble if you run the battery till cut-off, and then forget to charge for many months. This happens fairly often, believe it or not.
@Mike Owen Based on the WWW, it looks like your eBike has lights and eShift... Both of these things add to the size of the reserve power. As an eBike sits alone, the low-voltage cut-off is pretty slim. It's the 2-hours of lights + 50-100 eShifts that really add up. Lithium battery cells have a very slow self-discharge rate so it doesn't need to be a lot on it's own. It's the lights and eShift that do it.
I agree, it would be cool if this was possible:
"My ideal Bosch update would be: allow user via Kiox to adjust Powertube reserve right down to Battery protection level. That way I could use more of that currently inaccessible 100Wh range and leave the last battery to cut out at 50Wh in case I screw up again."
The Drive Unit "makes the call" on reserve power based on light settings and eShift, so it has to treat all batteries the same. The only thing you could do to lower the reserve is to have your dealer deactivate your lights, which is not a good idea for safety or visibility. A better option may be to have the dealer lower the reserve watts (as low as 3 watts is possible.) You'd need to be aware of the safety implications of dimmer lights, but it should give you a little of that reserve power back. I'm not sure this would be even savings to be worth it.
