First thought is did you test ride them? Which one felt the best while riding?
Just going off spec sheets, the Giant is probably the nicest. Carbon frame vs aluminum on the Cannondale and Cube. The Fox suspension bits are likely a little nicer than the Rockshox on the CD/Cube. All 3 have good Shimano 12 speed 1x drivetrains (deore/XT/SLX). All have Shimano 4 piston brakes with 8" rotors. Component specifications are similar enough that I wouldn't buy one over the other based on components. All three are solid.
For suspension design, the Cube and Cannondale appear to have horst/4 bar linkage for the rear suspension. Giant uses their twin link design (Maestro). I've owned bikes with both designs. Both are good, but have a little different feel. A lot comes down to implementation. Test ride them. Make sure the shop sets sag correctly and bash around the parking lot and see how the suspension feels. Suspension travel
is a bit different between them. The Giant is 140mm R/150mm F, the Cube is 160mm R/170mm F and the Cannondale is 150mm for both.
For the electric system, Giants website says its an 800whr battery vs the 750whr on the other two. Note that Giant uses Yamaha motors, not Bosch. The other two are Bosch. All three are comparable full power systems.
The Giant and Cannondale have 4 sizes available. The Cube has 3. The Cube doesn't seem to have a small (as a short dude, their medium is borderline too large for me).
Bottom line, they all look solid. The test ride should be the main thing imforming this decision.
For suspension design, the Cube and Cannondale appear to have horst/4 bar linkage for the rear suspension. Giant uses their twin link design (Maestro). I've owned bikes with both designs. Both are good, but have a little different feel. A lot comes down to implementation. Test ride them. Make sure the shop sets sag correctly and bash around the parking lot and see how the suspension feels. Suspension travel is a bit different between them. The Giant is 140mm R/150mm F, the Cube is 160mm R/170mm F and the Cannondale is 150mm for both.
