It's a wilier, I got it replaced under warrantyhow much did the replacement battery cost you btw you also have a Cannondale Neo?? Thanks
Does anyone have experience with the Mahle warranty on this issue. My Orbea is a 2019 so is out of the typical 1 year warranty but only has about 15K miles on it. Mahle USA (actually the company that provides their customer service - QBP) says this is NOT a common problem, and therefore its not covered, but if it wasnt a problem the flange would not have been redesigned so quickly. Just wondering if any forced the issue and got Mahle to cover the motor replacement when it was beyond the warranty period.I have an Orbea Gain m20i with the x35 drive. Two of my friends with Orbea Gains have had damaged motor casings. One had it replaced under warranty by the dealer. The other just happened and I don't know the outcome yet. There is a thread on this forum that shows the same thing happened to two Ribble bikes with this drive.
The Mahle app is almost useless but for 2 features : (A) you can get a more accurate battery level than with the IWOC -- but my garmin also tell me the battery level -- (B) you can adjust the assitance level in green/orange/red. I switched mine to 33,66, 100%.Hi All,
I have recently bought a Cannondale Gravel bike fitted with an Ebikemotion. Working OK (the app is very clunky - having to go to settings to tap Connect every time etc. ) but the issue I want to pick brains on is this.
Riding along in Green (usually but may do same in Orange - not sure) and I come to a rise in the road. Seems hard work so check and find it is now in White (no drive). So I am assuming that the 'system' is seeing that I have been either 'freewheeling' or riding faster than the limit (I am in UK so 25kph) for more than a time setting so has reset me to White (sort of neutral) or there is a fault somewhere. No error codes are involved in this at all. Once I have changed it back to Green I have drive and can get up the rise OK. It hasn't done this going into White (as far as I can recall) while I am 'under drive' so I am sure it is more of a 'coasting / nuetral' thing.
While I am at it does anyone know what power is output under Green, Orange, Red all at 100%? I would like to remap Green to about 50% of its power and then have Orange and Red in logical steps of power so that I can use the different power settings a bit like gears.
Chris,Hi
I have an Orbea Gain M20i and have ridden 3000 kilometres. I have a problem with the ebikemotion x35 drive train. I I have had the problem since new.
The problem occurs when
1. The bike is going over 40kph
2. I am pedalling with some pressure on the pedals.
3. If I then back pedal the cassette seems to momentarily catch and chain would do a momentarily jump.
The problem doesn't occur if I just stop pedalling, only if I am pedalling with at least a little pressure on the pedals and then back pedal (not just stop pedalling).
I have had my Orbea dealer check it. He didn't find anything wrong but did adjust the drive train, and including increasing the chain tension. The adjustment did help ; the chain doesn't jump as much but it still occurs.
Has anyone any suggestions on what the problem can be?
Chris
Thanks for the suggestion. I will check the chain ring and the cassetteChris,
I have recently acquired a 2022 Orbea Gain M20i and on my third ride out I found myself diverted into a gutter and scraping the aluminum outer chain ring against a concrete curb. Wow, it does not talk a lot to wear away the teeth on these aluminum chainrings, so for all you Ultegra and DuraAce users out there, be aware that aluminum chainrings are not as durable as steel chainrings.. The local Orbea dealer explained that the very specific profiling on the chainring teeth is critical to avoiding unplanned jumps in the chain. Is there any possibility that either the front outer chainring or some of the cogs in the rear cassette have been damaged in any way that could be causing the jumping?
BCarlson
I have had a good look at the large chainwheel. There is no obvious damage although the dark grey surface coating has worn off on parts of the teeth. As the problem happens on all the smaller cogs of the rear cassette I don't think its the cassette. I suspect the cause is the free wheel system not immediately freeing up at that speed and causing the jump.Chris,
BCarlson
Hi. I have had an issue with the latest version of the app. Since upgrading if you change the power level with the app it returns after a few seconds to a lower level until it gets to zero. Even if done via the iwoc. Turn the app off and ok and stays on the level selected. A setting or a bug?No ebike is perfect, this is a thread dedicated to sharing known issues or problems with electric motors from Ebikemotion as well as any help and solutions you know of. Sometimes that means a DIY fix and other times it can mean a recall, software update or part replacement by a dealer.
Please be respectful and constructive with feedback, this is not a space for hate speech. In many cases, representatives from the company will see feedback and use it to improve their product. In the end, the goal is to enjoy riding and help each other go further and be safer.
I had an original X35 then got the new version when the flange broke on the original, and now notice this issue too. It happens when my cadence falls really low on hills, usually when I'm out of the saddle, I can feel the power cut out when I'm at the top of the pedal stroke. The problem goes away at higher cadence. Around the time I had to go to the redesigned X35 motor (is that an X35+??) I also had the cadence sensor replaced because it was showing signs of failure when the LBS was configuring the new motor. So not sure if the issue is more the motor or the sensor. But dont remember this issue as much (if at all) on the original configuration.it does this 'lurching' thing. When going up a steep hill, the power cuts out, just for a beat - no more than half a second - and then kicks back in again,
One major issue with my orbea vibe was that assistance would often cut of on very steep climb (8-10 % or more). On top it was a rear wheel engine to it dragged a lot anyway during climbs. I would advice people to avoid Mahle engine, Fazua is producing a similar engine but it is much better because :I had an original X35 then got the new version when the flange broke on the original, and now notice this issue too. It happens when my cadence falls really low on hills, usually when I'm out of the saddle, I can feel the power cut out when I'm at the top of the pedal stroke. The problem goes away at higher cadence. Around the time I had to go to the redesigned X35 motor (is that an X35+??) I also had the cadence sensor replaced because it was showing signs of failure when the LBS was configuring the new motor. So not sure if the issue is more the motor or the sensor. But dont remember this issue as much (if at all) on the original configuration.
Well, the shop said they took it for a 30 min ride and couldn't replicate the issue. But they upgraded the firmware. On the plus side, they didn't charge me.My local bike shop said they've seen the first issue before (the 'lurching') and think a reset and firmware update should fix it. I'll update with the results if I remember...
I purchased an Orbea Gain D50 with the x35 system back in 2021. I haven't used the bike much, circa 400 miles.
I seem to encounter the 193 CellOverVoltage error on a regular basis. In actual fact including the error appearing today (the bike was charging but had only reached 89% when the app suddenly presented the 193 error) it has been 7 times I have experienced this so far. I never charge the battery overnight or indeed above 98% as was advised by the dealer I purchased from (sigma sports).
I was advised by Sigma sports "running the battery down to 0% then giving the bike a full charge & then allowing the bike to charge for another two hours past the full charge point to recalibrate the battery". I have done this on each of the 6 occasions before today and whilst it has been successful it can take many days for the battery to run down as when this error is showing the motor doesn't engage so I have to leave the bike switched on with the app open on my phone.
As you can imagine paying over 2k for a product and having to "recalibrate the battery" every 2 or 3 charges is considerably frustrating.
Are you able to advise why this error keeps appearing? Is there something I could potentially be doing that is causing the error to appear?
