There are different recommended sizes for the small step-through (4'11" - 5'4") vs. the small step-over (5'1" - 5'7").Check the web site again.
There seem to be various types of Cadence sensing controllers
- Constant voltage - This drives a constant voltage to the the motor, based on the assist level, with the current limited by the controller. At low speed you hit the controller current limit regardless of the assist level. Thus, you get a hard shove even at low levels. The Aventon and Magnum Metro, among other bikes, has this type.
- Constant power - The controller tries to feed the motor a constant power based on the assistance level. Thus,
at low assist levels you get a gentle push. Rad Power Bikes has this type on the Rad City. I much prefer it to constant voltage. You will still get higher torque at low speeds than at higher seeds but the drop-off isn't too steep.
- Constant torque - The torque stays constant based on the assist level until you are going fast enough to hit max power. I don't know of any bikes that have this, but there may be some.
If you are technically inclined, you can see the torque curves for constant voltage (the default) or constant torque (if you select a custom controller with constant torque) at https://www.ebikes.ca/tools/simulator.html. Changing the throttle setting is the equivalent of setting the PAS (pedal assist) level.
Finally, torque sensing bikes work differently, sensing your pedal torque and multiplying that power, giving a fairly natural feeling.
I have Aventon Pace 500 Sport in small frame size. I like the bike.
I have two complaints. The lowest Pedal Assist level PAS 1 is too high at nearly 12mph. Once you pedal the required 1 revolution before assist is activated, the motor quickly accelerates to 12mph in a few seconds. It seems dangerous to be turning slowly and just pedal once and have that high acceleration jolting you forward. The second complaint is no 0 start throttle. You must pedal 1 revolution before the throttle is activated. This is tough starting at a stop light and wanting to get across the street quickly using the throttle but only after that pedal revolution. All my other ebikes I have ridden had the throttle activated from 0 start. I have gotten used to these problems. But I wish Aventon would make this great ebike even better by fixing the two complaints.
Great explanation. My neighbor has the Pace 500 and has a lot of trouble with PAS surge. He has lost control a few times in tight turns. I have a Qualisports Volador and the power delivery is ultra smooth.
Hi Innovader and welcome. Why not start over. Connect the charger to the battery first just as Aventon says, and then plug in into the house current. The charger will initially show red and when fully charged it will turn green. I seriously think that you damaged anything. After the charger light turns green, it means the the battery is fully charged. Hopefully, you should be good to go after that. Please let us know what happens.
if the light on the charger is green, it means that the battery is fully charged.
