Ericmacfan
Hello All,
I am a newcomer to the E-bike world. I just contributed to a project on Indiegogo for the RadRover power fat bike :
http://igg.me/at/RadRover/x/7806061
I was seduced by the low price tag, looks and characteristics...
I would like your take on this...
This is the technical data, do you guys think it's a fair deal ?
Technical Specifications
MSRP $1499
Drive System Brushless Geared Hub Motor
Motor 750W
Controller 48 Volt 15 Amps Continuous (22 Amps Peak)
Display Display LCD Speedometer, Wattmeter, Odometer, Backlight, And Remote Handlebar Selector Buttons.
Suspension Front suspension fork with rebound and lockout
Battery 48V 11.6Ah Li-ion with 15 Amp Continuous BMS Samsung 29E Cells
Battery Life 15-50 Miles/24-80km* Depending On Mode
Top Speed 20 MPH/32 KPH On Flat Ground With 180lb/81kg Rider
Charger 48 Volt 2 Amp Intelligent Smart Charger Operates On Both 110 And 220 Volt AC Power Outlets
Throttle Half Twist Throttle And Intelligent 5 Level Pedal Assist
Weight 27 Kg (60.8 Lb)
Frame 6061 Aluminum Alloy
Headset Aluminum Alloy
Stem Aluminum Alloy
Handlebar Aluminum Alloy
Grips Velo Comfort Leather Grips
Front Brake Tektro Mechanical Disk Brake (180mm)
Rear Brake Tektro Mechanical Disk Brake (160mm)
Brake Levers Aluminum Alloy Comfort Grip Levers
Rear Derailleur 7 Speed Shimano
Chain KMC Z7 Rustbuster
Shift Levers Shimano thumb shifter
Cassette 7 Speed Shimano
Crankset 60 Tooth With Aluminum Alloy Crank Arms
Pedals Wellgo M111 forged aluminum
Rims Double wall aluminum alloy 32H with CNC side wall
Spokes 13 Guage Stainless Spokes And Nipples
Tires 26’’x4’’ / 660.4mmx10.16cm Kenda Juggernaut Fat Bike Tires
Saddle Comfort Gel Sport Saddle
Lights Front 200 Lumen LED Headlight Runs Directly From Main Battery. On/Off Switch Built Into LCD Guage
Fenders Optional Available After Campaign
Rear Carry Rack Optional Available After Campaign
Chain Guard Included
Kickstand Included
MSRP $1499
Motor 750W
Stem Aluminum Alloy
Kickstand Included
