pushkar
Check if your magnet and sensor alignment please. https://electricbikereview.com/forums/threads/travelanche-exess-hp-180-mods-for-the-better.40326/ from @greeno should help.
Yeah, first thing I checked. It's good. Is that a plugged in connection under the plastic side cover or does it run through the main cable? ThanksCheck if your magnet and sensor alignment please. https://electricbikereview.com/forums/threads/travelanche-exess-hp-180-mods-for-the-better.40326/ from @greeno should help.
it has its own cable - white connector. Hmm.. weird.Yeah, first thing I checked. It's good. Is that a plugged in connection under the plastic side cover or does it run through the main cable? Thanks
EDIT: Just checked the wiring that came with my Archon that I did not use and the magnet wire IS one that plugs in under the plastic cover LOOKS LIKE.
Yeah you lot package a new magnet ( thanks ) and sensor with a not very long wire and it has a white three pronged (shrouded clip type) connector.it has its own cable - white connector. Hmm.. weird.
What voltage does the light take?Yeah you lot package a new magnet ( thanks ) and sensor with a not very long wire and it has a white three pronged (shrouded clip type) connector.
On another note: anybody figure out how to get a light direct wired to the battery? I know the subject has come up but I can't remember where. Thanks.![]()
No real idea of the voltage. It's a little thing that came with the bike. Says: Cree T6 IPX-6 NO X3 on the side of it. It looks like something that would run off a couple of C cells. Maybe I can buy a battery cradle and wire it up on my own. The light has it's own switch on it. I have no plans to ride at night much, if ever.What voltage does the light take?
We are getting the new boards to do the lights. hoping end of Feb / early March. Will come with a splitter harness for lights and more.
Thanks Greeno. Just went thru the display settings and don't see anything. The cadence sensor must be partially working at least or as you say ... the motor would shut down. I guess my next trick is to replace the sensor with the new wire and make the connection under the plastic cover. I do notice this connector has three pins. Maybe one got bent out of position or something. Yes the speedo worked on the old motor but Wattwagons sent me a new display and I mounted that one.The rear cadence sensor does have a rather short cable with a white plug on its end. It only need to plug into the separate short cable that comes out of the motor housing so it should be long enough. That should be one of the connections under the plastic cover. As far as I know with the lights is that the motor is kinda wired for aux lighting but the controllers aren't programed for them yet. Otherwise you can go with a separate power source and switch in the meantime or go with a rechargeable one. The main harness cable has (2) plugs for the brake cut-offs, throttle, and display. Since I am not using the brake cut-offs I am using one of those plugs for my shift sensor and the one coming from the motor housing I safed off. Funny why you wouldn't have speed on your display. From what I know if the cadence sensor doesn't receive a signal pulse after a short period of time it shuts the whole system down BBSHD for sure and I think the Ultra also. Could it be a setting on your display that isn't enabled? Most importantly did it ever work in the first place?
Ah, screw it. Who needs a speedo? I may try to look at the cadence sensor plug. I don't want to pull the 4 main cable plugs again. Those delicate little things don't look like they can take much. Besides I tried to pull the green connection last night and it is stuck stuck stuck and I have pretty strong clod buster hands.Can you swap to the old one and see if that still works?
When I upgraded my wheels I had a issue where it all worked but the speedo did not, turns out that I forgot to put the magnet on the new wheel "Duh". So check your magnet is aligned with the sensor.Got My Throttle back. Just by messing around really. Decided to install the new throttle that came with the Archon X1 as previously I had just left the original identical throttle on the bike and plugged it into the new main cable. Low and behold. Throttle works fine. For all I know just the act of unplugging and plugging back in might have done the trick. Regardless ... I now have throttle again.
EDIT: Which allowed me to cross a creek which runs between houses here without getting my feet totally wet. Just damp. And I found out my back fender is way too short to the rear. Thanks Kyle.(nobody's perfect though)
Still have no speedometer however. Power use on the display graph works but speedometer does not. I have no freekin idea. Any help much appreciated.![]()
