Is anyone trying to solve charging on the road?
Thanks for the link, I read several articles there. I see that you specifically quoted me saying I typically wait 30+ minutes after a ride before I put the bike on charge. I haven't found any content on Battery University yet that specifically addresses that, yet. Should I be looking for something specific?
Nope... I think it's the pack's temperature that is the most important factor. I learned a lot from that site.
Gotcha. I did read that after 90 minutes of the battery chemistry settling down that the computer gets a more accurate reading of the charge level, but I can't assert the accessory of that information. :)
I researched Lithium batteries, found what I thought was the best manufacturer and size battery for the style riding I do. I bought and used my 1st 28Ah pack only charging with a Grin Satiator for about 3K miles riding... and then bought a 30+Ah. Whenever I have a question about them or how to properly use/maintain them I just send an email and their experts and within a couple of days I get my answers. I have never heard anything about Lithium batteries needing time after use before charging but it's not going to hurt, especially if they are chilly.
It does make sense, at least from my view. It usually takes a few minutes for my packs to stabilize to settle at a given voltage after stopping. Often a volt or two higher. So if they are somehow recovering from use it makes sense to wait and charge a stabilized pack. It just seems common sense.
So does buying a 52V pack large enough that you never discharge past 45.4V and can still ride for 80 miles.
I'm definitely on board with buying at least one big battery, what with the wind and hills and cold.
The only supplementary system for camping trips that I could possibly foresee for now is having a small gas generator in tow.
That would be great for car camping and doing long day rides then coming back and charging at night with the generator. But even a small lightweight generator is too heavy to lug around. I use a 17 lb. 300W folding solar panel to charge the packs spring, summer, and fall. The only disadvantage of a 30Ah pack is the weight and the initial cost... all the advantages make it worth both.
I'm seeing the small generators weighing in at 50 lbs. Not good, but at least maybe possible to put in tow?
I've been eyeing a small towable gas generator for some time now for extended off grid bike touring. This one caught my eye:
It weighs just 21 pounds and puts out 800 watts which is enough to power a couple of battery chargers with some left over for camp use.
In theory, you could charge a spare battery on the trailer while riding and never run out of juice.
  1. I've been eyeing a small towable gas generator for some time now for extended off grid bike touring. This one caught my eye:
    I have seen those also, they are available under different brand names. Some mixed reviews on Amazon. Of course if your buying gas to "fuel" your eBike it's kinda missing the point on ePower. That said, if your looking to achieve range can't see it not working. 20# is pretty light.
6zfshdb, Thank you for the information! 15.6" x 8.2" x 14.0". That really puts the dream of forever riding within reach. It could even be put as one side of a set of panniers.
Gas is 6 lbs per gallon... how many of those are you going to carry between your refills? A generator isn't feasible.
If you don't mind sharing I'm curious as to what each of the bikes were/are and what you have your eye on i.e.
55 lb. bike?
49 lb. bike?
42.5 lb bike?
I'm guessing the 33 lb. bike is the BMC Alpenchallenge Road One?
55 lb bike = iZip E3 Moda
49 lb bike = Raleigh Tamland iE (46 pounds originally, but 49 pounds after I swapped to Schwalbe Energizer Pro tires)
42.5 lb bike = Felt Sport-E
33 lb bike = BMC Alpenchallenge AMP Cross LTD (I was interested in the Road One, but switched to the Cross LTD after I started getting tendonitis in my arms on drop-bar bikes)
I also have a Haibike XDURO Race S 6.0, but that's a different kind of bike for a different kind of riding. Whereas I replaced the iZip with the Raleigh, and replaced the Raleigh with the Felt, and may replace the Felt with the BMC.
I don't know. How much fuel would it take to charge 2 x 20Ah batteries?
Actually if these 800w gens are like my Honda 1000eu I get about 7 hours per 1/2 gallon. How much fuel would you actually need to carry? 6lb's worth? By the way, I get 7hours charging my goal zero yeti ( while connected to my Dometic 65 ) and while plugged into my Aframe camper .... running led lights, Echo, phone chargers and ......drum roll, LG 5000 btu a/c on low.
Anti eBike folk would love these past few posts.....fossil fuel to fuel your zero emission eBike. LOL
I will say this, the Honda 1000 would be out of the question , it weighs way too much but 19.8 +6....not so bad .
21lbs is slightly more than my carry weight, with bike bags, tools, clothes, and camping gear.
So that little generator would basically double what I haul. I don't think so...
Do you carry your stuff on the bike? I am assuming this hypothetical is towed weight.
