I am a e-bike newbie, so please be gentle if this is a stupid question.
I mounted my handheld GPS (a Lowrance Endura Sierra) on my new Gazelle Arroyo today and went out for a short 6 mile test ride. I had the GPS trip meter set up to show speed, elevation and distance. The speedometer on the Intuvia display consistently showed about 1 to 2 MPH faster than the GPS speed. My average riding speed was about 14 MPH, so a 1 to 2 MPH difference in the speedometers is pretty significant. My experience with GPS devices is that they are pretty accurate on speed/distance measurements, so this concerned me that the GPS and Intuvia speedometers did not match more closely.
My first thought is that the LBS didn't set the wheel circumference correctly in the Intuvia setup. It is set at 2205. To measure the actual circumference, I made a mark on the tire where it was perpendicular to the garage floor, then rolled the bike forward until the mark was again perpendicular, and measured the distance between the two points. It measured 87 1/8" which calculates out to just under 2213.
My thinking is that with weight on the bike, the compression of the tire would cause some reduction in the effective circumference, but even if 8mm is significant, it seems like it is in the wrong direction for the speed discrepancy I am seeing. Wouldn't increasing the circumference setting actually increase the displayed speed for the same number of wheel revolutions in a given time?
Please tell me if my methodology is flawed, or if I am expecting too much from the Intuvia speedometer.
I do have another GPS (a Garmin Oregon) so I intend to repeat this experiment to see if I get the same results with the Garmin.
