Solarcabin
- USA
So after getting some help from another Ariel X rider he said a larger crank set would definitely increase resistance and he and others are using this one:
If you are experiencing the same problem and want more pedal resistance on your ebikes that may also work for you and I have ordered one and will report back if that helped.
Thanks to the people that tried to help and I have learned a valuable lesson to not expect help on EBR in the general discussion section that appears to be inhabited by a clique of stupid trolls doing everything they can to run people off EBR.
60T 170mm Crankarms 130 BCD Fixie Crankset for Single Speed Bike, Fixed Gear Bicycle, Track Road Bike (Square Taper, Black)
