Gionnirocket
- USA
- City
- Y. O.
Yes, plug the charger in to 110.I think you must be right. There is no on/off switch on the batt. but the control module on the handle bar turns it on for sure. ( must be talking to the battery management ???) I will see if the charger can wake it up. Do you mean to say that it will stay activated (wake up) for a period of time after I unplug the charger, or will it have to be plugged in to keep it activated? Does the charger have to be plugged into 110 also to cause it to wake up?
If this is the case it will depend on your particular BMS for how long the output terminals will stay active. It could be on time delay or it may need to see some input continually whether it be a charger or the handlebar controller.
Safety devices sometimes make it difficult to test or to use a device in a manner not intended
