smorgasbord
- USA
Where did you read thd advice to deflate tubes with tannus? I just want to check the details - ie if the kids rude regularly do I need to deflate occasionally, or us it mire a probkem that you get flat spotsinnsections of tannus?
I RTFM. It's also online in the FAQ:
Tannus FAQ
S U P P O R T Tannus Frequently Asked Questions TANNUS ARMOUR What is Tannus Armour? Tannus Armour is an insert that sits underneath the tire and over the tube. It offers puncture resistance, comfort, and enhanced riding capabilities. Is the price for one or a set? Each insert is $40. So a set...
tannusamerica.com
The armour will compress some after it’s installed depending on the pressure of the tire. The higher the psi the more condensed the Armour will become. If you wish to keep the Armour as thick as possible then maintain a lower psi. You may also deflate your tire if you’re not going to be riding for a longer period. This allows the Armour to rebound back to its original size.
