New conversion kit, and I'm getting no response whatsoever from either the throttle or the PAS.
Battery is putting out 40.5 volts, and it's a 36v motor. Controller is set to 36v, and it is showing battery is 100%.
I went through the settings, and made sure P10 is set to 2, which enables both throttle and PAS.
Spec sheet here:
I checked the function of the brake cut out switches, and they are normally open loop, so have just left them disconnected, although connected and disengaged made no difference.
Double checked all the connectors and they are well seated.
Tried both throttle and PAS connected to both inputs (3 pin yellow connector), and neither work at either input.
Any other ideas? Have already contacted ebikeling for a return.
Spec sheet here:
