Ha, thanks for reminding me to follow up here
The bad news is: unfortunately the bike arrived in a not-quite-rideable condition.
The good news is: the retailer (San Diego Fly Rides) is doing a great job hassling Gazelle on my behalf and making things right.
The bike itself is awesome, and once the issue (described below) gets ironed out, it's going to a ton of fun to ride.
But meanwhile, the issue(s):
When the bike arrived, the battery was absolutely
stuck inside the frame's battery cavity. I looked over instructions carefully, diagrams on Gazelle's site, re-watched the video review of the T10 Speed ... but all of these suggested that when I unlocked the battery (the newish PowerTube 500) it should just pop out of the frame without a lot of force.
I used plastic levers and eventually had to apply a
lot of force to get the battery finally out of the frame. I damaged the battery cover in the process – but fortunately this is a cheap and easily-replaced part.
After the battery was finally out, I played with it over the course of a couple sessions / couple of hours to see what was up. If the battery cover was attached to the battery, it was virtually
impossible to get it back into its slot in the frame. Which means somebody at the factory just basically
shoved it into the frame prior to shipping – thus the origin of my first problem
Eventually I figured out the full extent of the mistakes that had been made:
- Top battery bracket
Inside the frame, there's a bracket near the top of the downtube, where the battery makes positive electrical contacts. This bracket also sets the depth of the battery, aka how far it should sink into the frame. This bracket had not been adjusted at all, which meant there wasn't enough space for the battery to slide into position. Once I found and adjusted it, the battery finally fit into the frame easily.
- Battery lock spring-assist
On the other end of the battery near the bottom of the downtube, there's the battery locking mechanism. The rotating arm of the locking mechanism is supposed to be spring assisted – this makes sure that the lock always pops back into the correct position after letting go of the key, and it helps "pop" the battery out of the frame when you're removing it. The lock had been incorrectly assembled so the spring was just sitting there, disengaged from the locking arm, doing nothing at all. Once I saw what was supposed to happen, I reassembled the lock and it started behaving for the first time.
- Missing battery damper
Once I fixed the first two problems, the battery made positive electrical contacts, it popped into and out of the frame smoothly, and the bike seemed ready to ride! So I rode it a couple of miles around the neighborhood. The good news is that this bike seems awesome for me. The drive system kicks in like butter, and feels plenty powerful for my taste. The remaining bad news is that every time I hit the slightest bump, the bike loses power for a moment. By this point I had gotten in touch with the head of service with the retailer, had sent him a couple of videos, and he confirmed that my bike seemed to still be missing a battery damper, which I gather is a foam plate or gasket that helps the battery to maintain solid electrical contact while it's being bounced around. Without the damper, well ... it bounces around ![Beaming face with smiling eyes :grin: 😁](https://cdn.jsdelivr.net/joypixels/assets/7.0/png/unicode/64/1f601.png)
Next steps ...
All this ^ has been pretty disappointing to say the least. But on the bright side, the retailer has been on my side from the start. So they've agreed to provide the following:
- Talked to Gazelle on my behalf, who is shipping a new battery cover, and a new damper
- Will be giving me a $100 credit to cover my time and disappointment
- Recommended that I get the battery / frame hardware precisely adjusted by a local Bosch-savvy bike shop – and they will reimburse me for the labor
Those pieces haven't arrived yet, and I'm waiting to see the $100 credit on my CC statement, but ... they've been up-front and helpful from the start, so I have high hopes at this point.
In conclusion:
- Gazelle CityZen T10 Speed:
![Confetti ball :confetti_ball: 🎊](https://cdn.jsdelivr.net/joypixels/assets/7.0/png/unicode/64/1f38a.png)
![Thumbs up :thumbsup: 👍](https://cdn.jsdelivr.net/joypixels/assets/7.0/png/unicode/64/1f44d.png)
- Gazelle quality control:
![Thumbs down :thumbsdown: 👎](https://cdn.jsdelivr.net/joypixels/assets/7.0/png/unicode/64/1f44e.png)
![Pouting face :rage: 😡](https://cdn.jsdelivr.net/joypixels/assets/7.0/png/unicode/64/1f621.png)
- San Diego Fly Rides:
![Hugging face :hugging: 🤗](https://cdn.jsdelivr.net/joypixels/assets/7.0/png/unicode/64/1f917.png)
![Face blowing a kiss :kissing_heart: 😘](https://cdn.jsdelivr.net/joypixels/assets/7.0/png/unicode/64/1f618.png)
