Expand the budget a bit and get the Trek Verve+
You'll thank us later.
Otherwise the Aventon Pace models would be another option depending on what your local bike shop has.
Lots of specialty shops popping up.
I can't imagine "clipping in" in traffic. On a road bike on a dedicated track or bike path, maybe that is terribly efficient. You can pull up on the pedals as well as push down. On the street in a city where you are supposed to stop and put your feet down every block or two, sounds very cumbersome. Besides the OP said he didn't want to sweat before arriving at work, and using the pull up muscles in addition to the push down muscles just increases the calories burned. I can ride 30 miles without clipping in, and without electricity too. I lost 60 lb doing that, so the calories are going somewhere without using the pull up muscles.A commuter bike should have full leg extension and clip in pedals for the most efficient peddling effort. That is far from achievable with those moped-ish, mini-bike look alikes. Stay with a full sized bike.
Thanks! I'll check him out.Finally sorted the shop. Chalo at East side pedal pushers!
Please follow up and send me a note regarding how it went? I like to keep my referrals fresh, current, and accurate!Thanks! I'll check him out.
That is a great bike and one I took a test ride on. It was between the Giant and Trek.If you're going to spring $2400-ish for the Verve+, you might as well look at the Giant La Free E+1... Same price, more power, and mid drive with belt so you don't have the chain issues...
Interesting. My mids havevthrottles and operate exactly like a hub drive. A BBSHD can be ridden without ever shifting on flat roads....BTW, the chief advantage for a hub drive is that you dont have to pedal - or just turn the crank and the hub takes over - full power.
I knew it would be a perfect setup for the wife.
My fancy mid-drive has to be pedaled. And you have to shift it! Nearly twice the price!![]()
Got some test rides in at my local Bicycle Sport Shop yesterday -- my first time sitting on any ebike, and also my first experience (even window) shopping at a serious bike shop.
The ebikes they had available for test rides were a Specialized Como 4.0, a Verve+ 2 Lowstep, and a GoCycle GS. I took a round on all three just to get a sense of fit, feel, differences, similarities, etc.
Some casual observations:
- Big name mid drives + torque sensing -- feels like magic!
The Trek and Specialized both felt really powerful, and I definitely got a sense of what people mean about torque-sensing mid-drives (or maybe just torque-sensing?) creating a feeling of smooth ramping added power. I start pedaling, the pedaling is easy, and suddenly I'm going 20mph. Pretty fun feeling. I get why people like these
- Contrast with hub drive(?)
The PAS on the GoCycle seemed less smooth -- I'd pedal for a half turn or so, get a boost, and it wouldn't seem to last long; but there was a pretty binary feeling between [boost / no boost]. I wonder if this is a decent exemplar for the difference between a hub drive and mid drive? The bike tech I was working with readily acknowledged that he "wasn't the electric guy" in the shop, so it's quite possible the bike wasn't in the right mode to represent "typical" assist levels for commuting. Granted, there's a lot of noise in this signal as well -- the GoCycle is a mini, folder, and its hub drive is on the front mounted. Any bike I end up will probably not be a folder, will probably have a rear wheel motor (if not a mid drive), and most likely have 26" or larger wheels.
- Plush SUV vs. nimble hatchback
As far as fit and feel comparisons to my little 26" MTB-frame commuter ... the Como and Verve both felt like stepping into much larger vehicles, like going from a little familiar hatchback to a large comfortable SUV. I'm not sure I loved that so much. This is where I just may not be imagining the future correctly -- I like the semi-athletic feel of being on my existing bike, but if my whole point is to start replacing car trips with an ebike, then maybe that ebike should feel a little more car-like than my current bike. The Como and Verve both felt a lot more car-like than the GoCycle. And I'm using the GoCycle as a stand-in for any lighter-weight ebike I might consider, such as the Propella, maybe the M-Class, etc. Curious for any thoughts or shared experiences on this point.
- First experience with small tires -- fine!
The GoCycle was also my first time riding something with <26" wheels, and I actually found it ... fine! Cruising through a large empty parking lot at ~20mph, it felt plenty fast and plenty stable, or stable enough for my needs. I suppose I'm used to avoiding cracks and potholes since my existing bike has no suspension -- so I imagine I could happily do the same with an ebike. This raises my hopes for something like the M Class (or comparable) if I don't end up going with a higher-end name-brand buy from an LBS.
Mostly I'm just using this post to process through the experience and see if anybody can relate, and/or would care to contradict. At this point I'm still largely guessing what my future usage of an ebike might be like. Happy to get further comment on any of this.
As for getting closer to a buying decision ... I'm pretty sure I'm going to reach out to MOD here in Austin and set up a consultation. They seem really service-oriented as a company and very passionate about supporting their customers. At very least I'll get to test ride their Berlin which will be a really useful data point.
Other than checking in with other local spots for test-rides, I am probably just biding time until Black Friday / Cyber Week sales.
@Greg Johnson this is helpful data! Thanks.
I'm a little confused ... you said not for me when it comes to mid drives ... but you have a Verve with a mid drive, and you give it some props for the easy tire-change that you get as a result. What am I missing here? You do or don't like mid drives?
It's probably good for you to point out that the Verve (and the other members of its weight class) are a good deal lighter than some of the most-popular affordable ebikes like the RadRunner -- or just, most things from Rad and Juiced and so on. It's all relative, huh?![]()
>snip
The GoCycle was probably set to level 1.
Here's my kitted Electra Townie
PAS is notchy. Mine had minimum speed 11 mph and minimum acceleration 500 W. WAAAAY too fast. I scrapped it and went to throttle only controller. Cheaper, more reliable, no display to ***** up in the rain.Oh this makes a lot of sense then. The tech who set me up on it probably didn't know how to set me up on the right PAS level. Thanks!
I'm gonna have to read more of that thread / hit you up about that kit conversion. Looks really nice!
As I've already advertised in this thread, I'm really happy with the shape and feel of my existing 90's-era Gary Fisher ... but I just don't want to have to work so hard to get across town! So that led me to give some serious consideration to the conversion route ... but then immediately I have to wonder how seriously I want to get into the ongoing business of maintaining my own converted ebike.
The key to a painless conversion is a suitable bike/kit pairing. I expect your Gary Fisher would require some custom tinkering. Probably not a good match. A newer Specialized Roll makes a good pairing and is nearly plug-n-play. All you need is to swap out the trigger shifters.
