Have you tried adjusting your front shocks? Also, many people find a shock absorbing seat post helps give them a smoother ride.Do you find your level a little stiff ?
I just purchased a level, absolutely love the bike but feel the ride a little stiff especially over Bumpy pavement . Any experience - or advice . My tires are stock and lowered to 50psi
Front shocks are in the softest setting . I think these puncture resistant tires are on the firmer side . I will reduce the air pressure a little more. The pavement I ride on in the city is not exactly the nicest to commute on thank god for some of the bike lanes - they are a lot smoother than the street .Have you tried adjusting your front shocks? Also, many people find a shock absorbing seat post helps give them a smoother ride.
Be careful letting the tires fall too low in pressure. They are rated for max PSI of 80, so dropping much below 50 PSI, you risk the possibility of pinching the inner tube between the tire and rim on uneven ground. You may want to look into a shock absorbing seat post. Also, since this Level is new to you, another option is returning it in favor of purchasing an Aventure with the fat tires.Front shocks are in the softest setting . I think these puncture resistant tires are on the firmer side . I will reduce the air pressure a little more. The pavement I ride on in the city is not exactly the nicest to commute on thank god for some of the bike lanes - they are a lot smoother than the street .
If heavy, reducing psi may result in bottoming out? Easing off the shock preload helped for me.Have you tried adjusting your front shocks? Also, many people find a shock absorbing seat post helps give them a smoother ride.
Is there only an adjustment on one side of the shock if so it’s fully openIf heavy, reducing psi may result in bottoming out? Easing off the shock preload helped for me.
Ok I will look into itI have been using the Suntour NCX Suspension Seat post since January on my two Levels and my Fat Bike. They make all the difference.
What size seat post ?Ok I will look into it
I don’t realize there were 2 adjustments on both sides of the shocks .. i adjusted also the rebound .. much better now !
27.2What size seat post ?
