Right, I understand that. I'm assuming that people riding Giant Explorers are not road racers, but are commuter/tourers as I am.Generally speaking...
You can read a lot about proper bike fitting on the web... the key contact points of adjustment are the bars, saddle, and pedals.
- Road riders and racers typically ride with the bars lower than seat height for better aerodynamics and speed.
- Commuters and most other riders typically ride with bars higher than seat height for better ergonomics and comfort.
Bike Fitting Basics | REI Co-op
Learn how to size a bike for a great fit. We’ll explain how to check standover height and seat position, as well upper body position. Plus, we’ll help you learn how to choose your bike size when shopping online.www.rei.com
This Is Why You Need a Good Bike Fit—Plus How to Get One
If you take one step toward better, more comfortable riding this month, make it getting a good bike fit.www.bicycling.com
I can't afford to buy new stems of different heights to see what works best so I wanted to survey other owners.
How are your bars set?
Terrific, Thanks. I'm 6'1" with 32 inseam & 35" arms How does that compare with you?
I'm going to have to take it back to my LBS because they had already installed a stem with a 45 deg angle rise.
What seat post did you buy? I bought a Pro PLT seat post with a 20mm offset but it looks like it is the same offset as the stock post.
It is quite interesting observation FlatSix911 that the same 3" riser makes the handlebars be higher than the saddle on a hybrid bike but on the same level for the MTB. Noticed the same?For my mountain bikes, I like to have the bars and saddle about the same height which helps with technical descents.
Good info, thanksAh, about 6'3", 34" inseam and arm about 36-37" here to use your bizarre measuring system , so a bit lankier but in the ballpark I guess.
I didn't end up getting a seat post as the stem riser gave me the extension I needed, fortunately. You may need one with a bit more extension if yours feels too low or close. There's some interesting options out there that can get the bars up and away from you more: https://www.pushys.com.au/bbb-bhs-34-highfix-120mm-os-25-4-bar-adjustable-trekking-stem.html.
The cabling will limit how far you go. I've got the 90mm stem and truth be told there doesn't feel like a massive amount more give on the cables from there so might be best to get your Giant dealer in on the conversation.
This was the seat post I almost bought: https://www.wiggle.com.au/ritchey-comp-2-bolt-seatpost/. I've jammed my Brooks as far back as it'll go - to the point where the rails narrow. The seat post marker is sitting on 135mm at the bolt. Leg extension feels good to me.
Getting a fit can be finicky. This is the first bike I've tried to get a perfect fit on and it's taken time and trial and error. It's worth it though - I find mine a sublimely comfortable commuter now after about 40 hours in the saddle.
Perfect, thanks. How high did you set your stem and did the cables limit how high you could go?
