Edit: scratch the Juiced remark below. Just saw you were from Denmark.
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I have the Sduro S6.0 which is the direct predecessor to the Sduro S8.0.
The most obvious differences between S8.0 and S9.0:
- Sduro S 8.0 has a Yamaha PW-45. The 9.0 has a Gen. 2 Bosch Performance Speed. The Yamaha is a slightly better hill-climber, particularly if the hill is steep (greater than 18% grade). The lowest climb ratio gear on the 9.0 is 1:1.09.On the S8.0 it’s 1:1. The Yamaha engine also has slightly more torque (63 No versus 70). More importantly the Yamaha has a lot of low end grunt. Even if you’re not in the right gear it will still climb. With the Bosch you will have to be in exactly the right gear. The Bosch requires 80RPM or more to climb. The Yamaha wil accomodate a very low RPM from the rider. This is important only if you climb hills that are 15% grade or greater.
- The S9.0 has an air fork. The 8.0 has a mechanical fork. The travel is greater in the S 9.0.
- The S 9.0 can accomodate two batteries, but you need to buy a special rail from Haibike. With that you can have to 1000Wh onboard. One battery will be a powertube, the other a power pack. See Court’s video for more info.
- The front lighting is better on the S 9.0.
- The S 8.0 has Zero Cadence, a sort of mini push that assist with pedaling as soon as you lean on the pedal and travel about 1/12th of a rotation.
-The S 8.0 is most likely not available in the US. Check with your dealer.
- The S9.0 has other obvious advantages due to the fatter tires.
Lastly and most importantly, if you want to maintain 28mph constantly because you have long, flat, straight stretches of road, then neither of these bikes is for you. They both cut off at about 26.5 mph and are extremely inefficient at high speeds. Get a geared hub instead. I suggest a Juiced CC or one of the other Juiced commuters. Those bikes maintain 28mph or higher with moderate battery consumption. Both the Trekking models will suck the life out of your 500Wh battery at 26.5 mph, meaning you’ll get little range. I own one bike, have covered about 800 kms on the S9.0, and have borrowed a Cross Current from a family member whilst visiting the US. There is no question that the Juiced is much better at Speed and moderate type rolling hills. Given your other post where you state that you want to commute at high speed, I don’t understand why you’re considering either Haibike model.
