Ravi Kempaiah
- Canada
- City
- Halifax
Ravi,
Do you have a summary of specs for the M1? Very sleek looking. I wonder about the hub power and battery range when off road with this. The mid drives are so efficient with the gears when going slow. Stealth bikes compensate with big power and big batteries >> high weight.
OK - I see it is 500W, 400Whrs. What is the weight?
Hi Dan,
Here is more info that I received from the retailer.
Here is some information on the M1 Erzberg S-Pedelec: This is with Shimano XT and FOX Float Fork. It is $7995.
We can do this with Shimano SLX and SRSuntour fork for $5795. This comes in Med (46cm BB to top of seat tube) and large (51 cm BB to top of seat tube). This bike weighs 21Kg
BASIC EQUIPMENT
Drive: Shimano XT
Derailleur Shimano XT
Derailleur Shimano XT E-Type
Crank Shimano XT, 44/32/22
Gear lever Shimano XT Rapidfire
Sprocket Shimano XT, 11-36
Chain Shimano SLX HG75
Pedals Shimano PDM530 Pedal, black and white
modulus of elasticity each with 2 removable 6 Ah Li-Ion batteries; ...
BRAKES
Brakes Shimano XT disc, 180/160
Brake lever Shimano XT
IMPELLER
Rims Mavic XM319 disc, 32/36, black and white
Hub Front Hub Dynamo Shimano DHS500, 32h, black
HR hub M1 hub motor, 36h, disc Intl. 500 W
Tire Schwalbe Rocket Ron Performance, Folding, 54 ...
CHASSIS
Damper FOX Float Factory, CTD
Fork FOX Float Factory 32 CTD, remote lockout, ...
Rate of taxation Tange IS245LT, tapered, integrated, aluminum ...
ERGONOMICS
Handlebars M1 31.8 oversize, 660x15 mm, black and white
Saddle Fi: zik Rondine
Seatpost M1 350x31.6 mm, black and white
Porch M1 7 °, 90/100/110 mm, black and white
There is also the M1 Erzberg Pedelec; with Shimano XT and Fox Float fork $6395. With SLX and SRSuntour fork $5395. This comes in Med (46cm BB to top of seat tube) and large (51 cm BB to top of seat tube). This bike weighs 19.5 Kg
Here are some specs:
CLASS SPECIFICATION
Transmission: Shimano SLX
Rear Derailleur Shimano SLX
Front Derailleur Shimano SLX, E-Type
Crankset Shimano FCM552, 44/32/22
Shifter Shimano SLX Rapid Fire
Cassette Shimano Deore HG62, 11-36
Chain Shimano HG54
Pedals Shimano PDM505 Clickpedals, black/white
eModul each equipped with 2 removable 6 Ah Li-Ion ...
BRAKE SYSTEM
Brakes Shimano SLX disc, 180/160
Brakelever Shimano SLX
WHEEL
Rims Mavic XM319 disc, 32/36, black/white
Hub Front Shimano SLX 32h
Hub Rear M1 hub motor, 36h, Disc Intl. 250 W
Tires Schwalbe Rocket Ron Performance, Folding, 54 ...
CHASSIS
Rear Shock Suntour Epicon, L-RP, 165/38/8
Fork Suntour Raidon SCRL-R, Remote Lockout, ...
Headset Tange IS245LT, tapered, integrated, Alu ...
ERGONOMICS
Handlebar M1 31,8 Oversize, 660x15 mm, black/white
Saddle Fi:zik Rondine
Seatpost M1 350x31.6 mm, black/white
Stem M1 7°, 90/100/110 mm, black/white
You can also do this bike without a motor, called the Erzberg Pure: with Shimano XT Fox Float fork for $4095. and with the Shimano SLX and SRSuntour fork $3095. This comes in Med (46cm BB to top of seat tube) and large (51 cm BB to top of seat tube). This bike weighs 12.4 Kg
