Trail Cruiser
At first glance, it appears non-intuitive to have bigger brakes to the front, But as you look around, this principle applies basically to all transportation with wheels. We cannot escape from the laws of physics, that as we slow down to a stop, the weight goes to the front while the rear lifts up (sometimes off the ground). The rear needs lesser braking force or it will lock up early and skid sideways. You see it (bigger front brakes) even on many electric bikes with 180 front and 160 rear discs.
So if you want improve your ebike's stopping power, upgrading only the front brakes may be enough to get the job done. I upgraded my front brake with 4-piston caliper (assembly consisting of left lever, hose, caliper that is already pre-bled) and it made a night and day difference on the stopping power of my ebike.
https://www.ebay.com/itm/TRP-Slate-4-Piston-Hydraulic-Disc-Brake-System-Left-Lever-Front-Caliper-Black/182792714551?ssPageName=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649&afsrc=1&rmvSB=true
