OK my buddys bike got dropped off this AM, no more further cost's except original purchase price plus the $870 VAT tax.
So...... I got to his place and bike was already unboxed and came partially assembled which would be standard I guess.
First impression the frame quality looks really good all welds are even and smooth, nice matte black color.
Bike was specs'd out for a Rockshox Yari front fork ( about $500)....... It has a DNM USD-6A inverted fork I'm pretty sure thats a sizable downgrade ( can't find a price but some of their components are listed on Amazon so thats not good). All I could find on the fork was it has adjustable air chamber and I'm guessing an oil damper on the right side with a rebound knob on bottom of the stanchion leg.
Plastic lower leg guards mounted and looks like around 150mm of travel. Axle pushes through fork and is secured on opposite side by a threaded cap and then there are tightening screws on lower legs to secure axle body itself to fork.
Never seen this before as it has brake caliper post mounts molded into BOTH sides of the lower legs so you can run your rotor right or left. Hub doesn't care so all you would have to do is pull the tire and remount it opposite so rotation would be correct. Also the hydraulic brake line would be pointing downward so unless they make a reverse caliper or one that is interchangeable ...Hmmm
Bike was also specs'd out for a XFusion O2 190mm x 50mm rear fork (about $340)...... and it has a DNM AO42RC rear shock ( $97.30 on Amazon) WTF BS if you ask me. I told my buddy to contact AK and have them adjust cost on downgrades. We'll see.
Tires are good Schwalbe 27.5" x 2.6" and the hubs are 100mm front and 142mm rear so NON boost spacing 32h and the rims are no-name and about 40mm wide so they should support 3" tires if he goes that way. Not sure if they are tubeless ready we'll check on that mañana as my friend had to go to work
Seat and Seatpost OK
Bars, Stem, and Grips OK
Brakes, 2 piston with 180mm rotors and post/post adapters included
Derailer 10spd Deore and shifter, lower end but will work.
Came with a DPC-18 display which we removed and replaced with a 750C
Bafang Ultra motor at least that's legit
48v battery charger
NO BATTERY or any info regarding it. We figured it would ship separately after reading numerous posts. Also since we won't be using it anyway and I will be making one that fits in the mid area it's not a big deal but a little com would of been nice from their end. Here's a couple of pics. I took a short video but I'm not smart enough to post it but I'll keep trying.
