So I just got my rear hub-drive kit in the mail today. I'll be posting more about that in the Dillenger forum, but I'm stuck on something more basic. Could use some help.
My kit came with a 9-speed rear cassette that was not installed on the wheel. Seems like it ought to be a really simple thing to install - literally place through axle, then screw on.
Here's my problem. I don't have the correct freewheel remover tool which I thought was necessary to also tighten the freewheel. So at first, I just tightened it by hand gently. At that point, the freewheel would spin backwards just fine, as you'd expect.
Unfortunately, I then proceeded to tighten it more, again by hand. Now, it doesn't freewheel backwards. Seems like it is on there too tight. Maybe or maybe not related, but the distance between the hub motor case and the largest ring on the cassette is so close that it does not seem possible that the chain could fit on that ring
I think it just needs to be loosened up, but I'm not sure. I've never worked with these parts of a bike before. I have a chainwhip took, but without the freewheel removal tool, I can't get this cassette off.
Any feedback or guidance would be greatly appreciated. Thanks!
Sqn
Sqn
