Charles Bartlett
If you are looking for a way to install a Bafang BBS-02 Mid Drive to your Fatbike with a 100mm bottom bracket, then contact Doug Snyder at California-Ebike.com. The key part is an extended axle designed by Doug and manufactured in the USA.
Take a look at the modified Bafang mid drive in action during recent testing.
For more information about the modified Bafang kit and the machining process, please refer to the official California Ebike Bafang Fatbike product announcement.
Note! This is not an "upgrade kit" that can be purchased to modify the Bafang kit you currently own. As much as Doug would like to offer an upgrade kit, the modifications to a stock Bafang mid drive are not a simple bolt-on affair. In order to warranty the modified Bafang drive, the extended axle must be installed by California Ebike.
