Last bits of info. These numbers come from when my battery was new, 800 miles or less. My daily commute is 5 miles each way on pavement with one 400 foot up and down hill each way. On PAS 4 or 5 I got the advertised 25 mile minimum. I don't use PAS 4 enough to break that out. PAS 3, got 35 miles, though the last 2-3 miles were iffy. PAS 2 used for 5 days straight, got 55 miles, rode the battery to cutoff on the 5th day to see what would happen and how far it would go.
Maximizing range: Don't touch that throttle. It is really, really hard to reliably apply an intermediate power amount such as 300w with the twist throttle; even if you get it right you hit a bump and your hand moves 1mm and now you're at 550-750w. In my impression, 5 minutes at PAS 5 (750w) drains the battery more than 10 minutes at PAS 3 (375w). When coasting to an intersection where you have to stop and you're cycling the pedals to gear down, pull a brake lever a little bit so the motor doesn't kick on. Pump up those tires to near max pressure; squishy tires are fun and necessary in some terrain, but they suck for mileage.
Also, when my rear kenda juggernaut (not a bad tire) wore out, I replaced it with a slick, resulting in about 10-12% faster cruising speed for same cadence in PAS 3. This doesn't directly translate to 10% greater range, since I burn the battery more getting up to cruising speed and my urban biking has lots of stops, but it helps since you get to your destination sooner.
