ebikemom
Hi Pedego peeps (with a special call out to experienced and expert Pedego peeps!!)!
This morning, my bike all packed up to head to church, BAM--no power. "Error 10." So, took the car to church. (The car was in shock, but adjusted fine, thank you. The trip to church may have even served to blow a bit of dust off of my car. No harm done!)
Looked up the error code on the handy dandy table, and learned this:
So, meanwhile, I'd texted my husband from church and he tried the bike. No problem. I came home and tried to find where the LCD cable connections are. Found what I figured is one of them wrapped under the black plastic strip wrapping sort of close to the LCD display. I gave it a firm little push inward from both sides. Maybe if I look harder I can find the other one.
Went out a bit later, grocery shopping with my son, and had three ERROR 10 incidents. All resolves when I did the same "push from both sides" maneuver on the upper cable connector.
Meanwhile, I think maybe I need to unplug and re-plug both connectors as instructed in (1) above. So, my question for you experts...
- How do I unwind the black plastic strip that is wound around the cables, and how do I re-wind it so it looks nice again?
- Where is the other connector end that needs to be unplugged and re-seated?
