Catalyzt
- USA
Okay, the good news is: I discovered a new trail in the hills behind Griffith Park that is, apparently, not illegal for bikes! There is a forbidding, but ancient, "No Trespassing" sign, but read it closely, and it applies only to cars and dumping. Carried my bike around the gate, and wow-- a cool, very primitive fire road with no horses! Yay!
It was just after sunset-- isn't it always? So I just went maybe a tenth of a mile down the road and then it seemed... like the road descended rather sharply. I then looked around in the dirt: Plenty of recent footprints, but... no bike tracks. At all. This is suspicious-- the Verdugo foothills are full of MTB tracks.
I looked at the road more closely... it bent around a semi-blind curve that's not obvious from the map below, but I thought, "Maybe that's steeper than it looks." Can't eyeball this kind of thing accurately. And it was getting dark so I turned around and rode out.
Found this trail on a map and yeah-- by the numbers, it's very, very steep. Have a look at the graphics below-- as you can see below, it's max is 37%, and is often over 20 or 25%, which sounds pretty intimidating. By way of comparison, Brand Park Motorway tops out at 19%, and wobbles around 10% to 15% for a lot of the climb, with occasional stretches below 10%. Brand Park Motorway, I know I can do-- it's a bit grueling for me, I have to stop several times, but I was never, ever at a point where I thought I couldn't go up or go down something, or had the risk of losing control if I was taking reasonable precautions. Didn't even seem close to that. So if I could manage 19%, is 37% really twice as hard?
All of this is really hard to read, just going by the numbers. For example, there are spots on asphalt that I know are 10% or a little more, and they seem like a huge slog to get up, while I now see that I was doing bits that were almost 20% on dirt that did not seem as intimidating.
What I worry about is getting into a situation where I will lose control going downhill-- where I literally can't stop without crashing-- or where I can go down, but can't get back up, even by pushing the bike for a half mile or so. (Did I mention that the E5000 "Walk" mode does not seem to work at all with manual shifting?) Here's what I imagine going wrong: I start heading down, and about halfway to the worst spot, maybe at .35 miles, I realize, "This is too steep," and I have to turn around... only once I do turn around, I can't find a spot flat enough to get started again, or it's so steep I have trouble pushing the bike back up.
I should note that I only plan to go about a mile down this road-- I know that it gets narrower past there (from satellite views) and also I know that the ridge trail along Cahenuga Peak is both illegal for bikes and also impassible-- too rocky. But that mile will take me to the coolest, most primitive area of the park where I have never been and few ever go. The prospect of getting there is really tempting. I imagine there are primitive wedge tombs from ancient civilizations we know little about... and there might be, though if they are, they would definitely be abandoned props from Universal Studios, which is right nearby.
Also, as many of you know, I'm a total rookie, and while I'm in pretty good shape, I do have a bunch of weird health problems.
This is a stupid idea, right? One of those ideas best thought of, chuckled at, and promptly forgotten, correct? Or is there some technique I could use for assessing the situation more thoroughly or something?
Thanks for your patience. Hopefully this post will provide some comic amusement, if nothing else!
