Johnitahoe
If looking for a solid front axle to replace an axle that is too short on my no name Ebike. It's 10mm with 1.0 Fine Threads and I need 190 mm in length. I see some advertised as rear axles. Can I use a rear axle on the front? Will any steel axle of the right dimension work? Is any of the steel harder (more durable) than others or are they all the same. I plan to take all the parts off my current axle and install them on the new one. Thanks, John
