Diameter Juggernaut seatpost
Islander
What is diameter of 2014 Biktrix Juggernaut seatpost? Looking to replace stock post with suspension post.
I just got mine yesterday....can anyone confirm that seatpost diameter is 31.6? Thinking of a Thudbuster.
My seatpost had 30.4 stamped on it. It would make sense the seat tube is 30.6 as they are usually .2 difference in size.
I found a 30.9 to 27.2 adapter I had lying around fit, after a bit of twisting.
Seatpost stamped 30.4
Grips
I did what I should have done before asking...took the seatpost out and it is stamped 27.2 mm. Maybe they're not all the same?
The 2014 Juggernaut frame looks completely different compared to the 2015 Juggernaut frame. Fred probably has the 2015 Juggernaut.
If I want to buy the suntour suspension post for 2014 Juggernaut do I purchase the 27.2mm post and reducer?
If your seatpost is stamped 27.2, purchase that size. Shims can always be used on a larger seatpost, if you were to sell it later
