mschwett
- USA
@BlackHand: The industry standard between major mid-drive motor manufacturers is Power = Torque * 6.28 rad/s (60 rpm). Yamaha and Brose 85 Nm motors have the rated peak power of 520 W (meaning the actual torque is 82.8 Nm). The actual 90 Nm motor (Specialized 2.2) has the peak power of 565 W. If anyone says the Bosch motor has bigger mechanical peak power then the torque should be a way higher.
you have mentioned this "standard" multiple times - please point us to the actual standard/document. there is no rule or reason i'm aware of to only refer to power at 60rpm, when a mid-drive may in fact operate at a wide range, say 50 to 100 rpm, and the controller could easily be designed to provide different amounts of power at different rotational speeds!
