Asher
I've been daydreaming about polishing the frame, like I've seen on motorcycles. Aluminum can be polished to a mirror finish. Not likely to happen, but it would be cool.
That would require sanding right? Pardon if this is a dumb question, but sanding a bike frame isn't enough to compromise the frame's weight tolerances or anything, is it?
Thanks, will try!I used goof-off to remove the decal on my titanium gravel bike. Should work for the brushed aluminum. There was some slight ghosting left from the decal and an Ultra Fine scotch bride pad removed that.
My primary reason for buying black was the juiced logo can barely be seen.
