Crosscurrent HMI replacement
wetdog2
Does anyone know if it's possible to swap out the King Meter T320 LCD with an LED display? If so, which one(s) are compatible? I'm only interested in getting more speed/distance/battery information, not in tweaking any settings.
Also, would it be as simple as swapping devices?
@Tora Harris
Has done all kinds of experimentation. Shoot them an email and I'm sure they'll be happy to help you out.
you could use a Grin Cycle Analyst, it is the gold standard for e-bike dashboards. You will need the matching shunt, and I prefer to use the optional bracket that attaches to the head tube. The CA is a little large and geeky looking, but it is accurate, and well built. You will need to cut the cable that goes from the battery to the controller, and make proper high current connections to the shunt.
692561044229658
