My 1000 W DD hub motor accelerates fine. I don't use it if I'm not trying to get across a 6 lane street in a 5 second green light from the 3rd position.Have either of you ridden a Bafang Ultra bike ? It will easily accelerate from a deep stop in the highest gear. Big difference from a 250watt Bosch.
Unlike a mechanical motor, the more I use my heart & muscles, the longer they last. More wear & tear, more T-cells. (see bbcnews.com/health) I'm hoping for 38 more years of riding.
It'll last longer if you don't beat on it.
So you're planning on getting rid of all the gears except the highest gear?
I don't see the problem with changing gears. You said you use it because it's there, but what's the problem with that?
Chevrolet Corvette Z06 can accelerate 0 to 175mph in 1 gear.
(According to Top Gear, I'm sure it's still on YouTube)
So no, Corvette only needs 1 gear because of massive torque, but I don't necessarily see the benefit of getting ride of all the gear selections.
If you find shifting gear that bothersome, then maybe don't shift as much but I honestly don't see the benefit.
Simple, yes. Efficient, no. Read audel's motor book about 3 phase AC motor performance. 90-100% of full speed is best efficiency. If you're not going very far you can waste the battery watthours by lugging, but the waste comes out as heat in the motor.
The reason trucks are going to 6 and 8 speed automatic transmissions is that it provides better fuel efficiency. 40 ton truck auto transmissions have been 6 speed for 50 years. Ie more range per fuel tank. Gallons of fuel is equivalent to X battery watthours.
BTW about riding a bafang mid drive, the nearest bike shop that has multiple brands for test riding is 160 miles away near Chicago. It is hub drives (pedego) or nothing in this state, and the next one too. I'm happy for you that you live somewhere civilized. Enjoy your tax rate.
In terms or practicality, I doubt if you can find a single speed sprocket that will fit in the holes of the 9 speed chain. Single speed chain is wider than 9 speed chain.
I think you're missing the point.
Sure, getting rid of all the components (longer chain, extra sprocket on derailleur, weight of derailler, etc.) may be more efficient on the particular gear.
In real life, in real cycling, you will be constantly accelerating, decelerating, ascending, descending, etc.
You will be riding in the inefficient wrong gear with mechanically efficient set up.
Which is not efficient overall, because the disadvantage outweighs the benefit.
You said "simplicity is tempting" but Juggernaut Ultra? That's hardly a minimalist bike, hard tail or full suspension.
I know it's your bike and my opinion is irrelevant, but still.. I would personally like to be able to change gear for the best gear ratio.
We all have seen single speed bikes, and they don't look anything like Juggernaut..
hmm then I don't know, maybe it does meet your needs. I've seen beach cruiser ebikes with single gear.
They don't typically come with highest gear though.. more like a little higher than mid range.
That would still require derailleur, extra sprockets, longer chain, shifter and all the stuff you've been talking about.
So you shift gear by coming to stop, get off your bike, put the chain on other sprocket, and ride again?
I'm sorry but that sounds a little bit silly..
yeah but I am assuming you have to take the wheel off and align it too, just like motorcycles when you change the sprocket.
You might as well just carry a different set of sprocket, instead of attaching it on to the bike.
Personally, I never understood why people want single speed.
You're not the first one asking about single speed conversion.. and I personally don't understand the problem.
You're spending money, time and effort on something that is not really upgrading.
What's next? lose ability to select assist mode?![]()
No, your opinion is valued. I'm in one gear (the top one) 95% of the time. Even from a dead stop, it just plain goes. Mine is stripped down quite a bit. No fenders, no suspension fork.
