Yes but no answer : (Have you asked Rafe?
He has a phone number. I see he does sell a motor with a 35A controller.Yes but no answer : (
Do you know if he has one?
BTW are you familiar with how to grease the motor? It's making strange sounds at times.He has a phone number. I see he does sell a motor with a 35A controller.
What do you mean by that?Once again we get half the story.
Yes please elaborate.Once again we get half the story.
Thank you!The problem that you're going to run into is that the 9-pin motor connector used in your kit is really only good for 30 amps, so most 35a controllers use a bigger connector that would be incompatible. There are some 30a controllers out there that should work, such as this one. If you just google "30a kt controller waterproof" you can find others. Just make sure they have the same 9-pin motor connector and 1-4 main cable (for the display, brakes and throttle).
It seems dishonest to market that kit as 1500w. Even with a 52v battery, at 22 amps it's only 1,144 watts.
That controller says it's 500w, will that fully push the 1144w motor ?The problem that you're going to run into is that the 9-pin motor connector used in your kit is really only good for 30 amps, so most 35a controllers use a bigger connector that would be incompatible. There are some 30a controllers out there that should work, such as this one. If you just google "30a kt controller waterproof" you can find others. Just make sure they have the same 9-pin motor connector and 1-4 main cable (for the display, brakes and throttle).
Awesome! Thanks againThe current controller is 11 amps continuous, 22 amps peak. Most sellers would market that as 500w (48x11). The 30a amp controller is 15 amps continuous. So that's about 200w more continuous power and 400w more peak power.
I'm not sure why they are calling it only a 500w controller but the math is simple. Maybe they are considering 36v only.
Edit: In response to your other question, there are no guarantees unfortunately but I'd say there is 95% that swapping one KT controller for another will have the same pinouts. I have done it myself a few times with no issues.
Exactly as stated! Who buys a motor rated for 22A and expects a controller change to 35A as a reasonable alternative? Motors have limited specifications. Some motors can be pushed, others are a nightmare overvolted. We see this all the time here. Buyers enter into purchases with little due diligence and then the reseller is the issue. ARGH, Rafe if a good fellow and responds to reasonable expectations. So yes, there's more to the story.What do you mean by that?
Ahem ! How the hell am I supposed to know the motor is rated only to 22a. There is NO documentation with the kit and as already stated Rafe is extremely slow in answering questions, if he answers at all, weather they are "reasonable" questions or not!. I am not the only one who has experienced this with him.Exactly as stated! Who buys a motor rated for 22A and expects a controller change to 35A as a reasonable alternative? Motors have limited specifications. Some motors can be pushed, others are a nightmare overvolted. We see this all the time here. Buyers enter into purchases with little due diligence and then the reseller is the issue. ARGH, Rafe if a good fellow and responds to reasonable expectations. So yes, there's more to the story.
Looks like you were wrong about the 22 a motor limit .Exactly as stated! Who buys a motor rated for 22A and expects a controller change to 35A as a reasonable alternative? Motors have limited specifications. Some motors can be pushed, others are a nightmare overvolted. We see this all the time here. Buyers enter into purchases with little due diligence and then the reseller is the issue. ARGH, Rafe if a good fellow and responds to reasonable expectations. So yes, there's more to the story.
Thomas is correct. If you put higher power controller you may fry motor and melt cable. The waterproof cables cannot take more than 1500w in my opinionLooks like you were wrong about the 22 a motor limit .
Now who has little due diligence???
