i purchased a 48v 10ah battery pack from china about 6 months ago, charged it up and set it aside until today. The battery pack has a c13 connector (like a computer power supply) and on those pins i get 34v. The charge port i dont know the type but it looks like an RCA plug, i get 18v. My charger is showing 53v. When i plug the charger in the pass through is 53v. I tested the fuse and it has continuity.
I took the pack apart, it is 12 polymer packs, each pack reads 4.0-4.3v. All BMS balance leads appear intact and voltage correct. From the output black and red wires from the pack i get 50.4v
I dont know a lot about this kind of stuff, but i am guessing there is something wrong with either my BMS or ignition switch. I was thinking of bypassing the ignition switch and just going directly to the output c13 plug but would like some input first...
