Has anyone changed tire size from 700 to 650? Pros vs cons?
A ActionJackson Well-Known Member Region Asia City Tokyo Aug 3, 2021 #2 favila said: Has anyone changed tire size from 700 to 650? Pros vs cons? Click to expand... What bike ? what is your goal? that mostly determines if a particular point is a pro or con .
kahn Well-Known Member Region USA City northWET washington Aug 3, 2021 #3 Timpo said: Your speedometer will be off. Angle of attack will change Your pedal/crank will be lower, and more easily hit the ground lol I only listed cons Click to expand... Doesn't adjusting the wheel size in the computer/setup fix the speed/distance aspects?
A ActionJackson Well-Known Member Region Asia City Tokyo Aug 4, 2021 #4 Timpo said: Your pedal/crank will be lower, and more easily hit the ground Click to expand... But note - just because your crank is lower it doesn’t mean it’s longer.
