ebiker4life
I have been comparing cargo ebikes for over a year. Mainly for groceries, but I want one that has potential to carry an adult passenger on occasion, like mopeds or motorcycles can (I have no kids). I checked out the Pedego, but it's too heavy. Now I've been dead split between 2 ebikes for months, but I'm leaning towards the Yuba.
Here's my comparison, anyone own or tried either of these and have any opinions?
Radwagon 2018/2019
++Affordable, $1.8k, 1/2 price of yuba
+Throttle 20mph & PAS, Class 2
+Regen brakes, USB charger
-Crowded and heavy rear wheel
Score: 3
VS
Yuba E Boda Boda 2017
-Expensive $3.6k
+Hydraulic Brakes, safe, Class 1 PAS ~16mph
+High efficiency/max range 90mi.
+Clean looking
+Low weight, only 60lb
+Great rack load capacity, 220lb (i may want to carry a potential girlfriends around)
Score: 4
Note, Yuba emailed me info about the eBoda 6 months ago:
Me:
Radwagon 2018/2019
Score: 3
VS
-Expensive $3.6k
+Clean looking
Score: 4
Me:
Re:"For the Yuba Electric Boda Boda: Are the dropouts on the front fork thru-axle or slots? What is the max rider weight limit? Does it have electric shifting? Will there be a new model of the Boda-Boda ebike with the new STEPS e6100?"
"Thanks for writing in! The front wheel of the Yuba Electric Bod Boda is a 9 x 100 mm bolt on axle, and not a thru-axle.
The rider weight limit is a nuanced answer. The seat post limit is 250 lbs but that also depends on height because the post can bend over time if it's at it's minimum insertion point, whereas if it is inserted most of the way in to the seat post tube (accommodating a shorter rider), it's unlikely to ever bend.
The Electric Boda Boda is designed with price point in mind and electric shifting is both unnecessary, and quite expensive. However, you could add a Di2 system to the bike, if you like. You'll need to build a wheel with a freehub body to accommodate an 11/12 speed cassette.
No motor change has been announced.
Bike on!
Tony@Yuba"
