Bruce Arnold
I live in an area with mostly level ground, so maintaining 26-28 mph is not that much effort. It affects battery drain more than my legs with the excellent Sport mode on the CCS. A month ago I was coming home from a conference and there was a storm out over the Neuse River. It was a 12 mile ride and I outran the storm in 90 degree heat without strain. Warmish, but not bad as long as I kept moving -- a 28 mph wind chill is remarkably refreshing. I don't typically ride that fast but I'm glad I can when I want or need to. I usually top out around 20 mph as air resistance does affect battery drain quite a lot at higher speeds.Hey @Bruce Arnold ! I have seen your posts in several places, so thank you very much for the info you have already given elsewhere. You have been more helpful to me than you know
That Wald basket looks great--do you need to do anything to get it attached to the existing rack on the CCS?
I have looked a bit at the CCX, it looks like a great bike. Viewing the specs here (https://www.juicedbikes.com/pages/compare-all-bikes), I do wonder if it is perhaps overkill for my needs, given that I can charge at work. Could you tell me any of the big benefits that I may be missing given my newness to the subject?
Last question--what is a reasonable top speed that you are able to achieve on the bike, and how long can you sustain it? I see many people post that after 20MPH, air resistance makes going faster exponentially more difficult.
There are 3 factors which make the CCX such a fine bike. In mechanical terms it is no different from the CCS. Electronically, it has the 25 amp controller and the 52 volt battery which come standard. Here are the 3 factors:
- Performance: The battery and electronics allow the CCX to operate at higher level of performance and for a longer amount of time. That doesn't mean faster necessarily. But you can get up to speed more quickly, you can maintain a higher speed for a longer period of time, you can demand more effort out of the motor without overheating the controller, and so forth.
- Distance: You would be able to ride the CCX farther at a given speed than the CCS.
- Fun: Feeling the bike respond vigorously to command inputs such as throttle or pedal assist is just a blast. Don't downplay this!
You can find a less expensive bike that meets your needs very well. The CCS, for one. Rad Power bikes have a good reputation too, and of course there are so many others listed on this site I couldn't name them all. But for the money, the CCX would be hard to beat.
Thanks for your kind words. I have found this technology to be life-changing and hope to help others enjoy the fun and functionality of ebikes.
