I recently bought my first, used electric bicycle. It was working well for two weeks.
Today, I got a flat rear tire and took it to a bicycle shop for a quick repair. In this town I am in, there are no electric bike repair shops.
After disassembly and reassembly to get to the rear tire and replace the inner tube, the motor no longer can deliver power to the rear wheel. Since this bike shop is unfamiliar with electric bicycles, they couldn't figure out what's causing the problem.
Here's what I have troubleshooted thus far:
Upon unplugging the battery from the controller and plugging it back in, the battery indicator lights work, and power can be delivered to the headlight. A small amount of throttle can be delivered continuously without cutting power, not seated on the bike with the rear wheel not in contact with the ground. In my opinion, it sounds like a lot of noise is being generated by the motor, although I can't say for certain it is more than what it was before the tire repair.
As soon as I apply more throttle (maybe around 50% or more), the power cuts out. Turning it off and on again does not power anything (the battery indicator flashes for a very brief period, then turns off). Throttle doesn't do anything. The only way to get to the state described in the previous paragraph is disconnecting the battery from the controller and reconnecting it.
I don't have any tools to repair this bike myself, and I'm very new to electric bikes. I would simply like to return to the bike shop with suggestions on how to fix the new issue (edit: I didn't want to imply they broke something on purpose).
Anyone have any suggestions?
Thanks for reading!
Thanks for reading!
