MatyasGreff
- Europe
Hi everyone, I'm new here and this is my first post.
I have an ebike(lapierre overvolt) with a bosch performance line motor and a bosch battery pack 400. Last night after work I connected the bike to the charger as usual and went to bed, by the morning it looks like the battery is fully charged but the bike has a weird problem where it turns on only for a second then turns off. This is while it's unplugged from the charger. When it is plugged in, the bike seems to be able to turn on but only to display the current mode(sport, eco, etc). As normal it should not be like this at all. Normally, when I put it on the charger it stays turned off and only displays the little charging symbol on the purion display, and when I disconnect it it should power on by itself automatically. Also, when I try to turn it on, it beeps 3 times then makes a weird noise, something similar to a radio's static noise before turning off, this might be normal, I'm not sure as I never listened closely when turning on the bike. I tried replacing the batteries in the purion display, checking the connectors, took the crank arm and plastic plate off the motor and disconnected/reconnected all the plugs but the problem still persists. I have no warranty, please advise.
