I just received my RadCity 4 Bike on Monday and did lots of riding and learning how to drive this bike.
My first ride was up a 10+% hill 1/8 Km long and return down the hill using regen to 15KPH and speed up to 32 and regen to 15.
It felt as if the regen was slowing down my bike to fast and could not stay going unless I let go and regen after 32KPH`.
I did that same hill 3 times that day with same results.
Later i went on an 8 KM run in hilly terrain while starting in the previous hill. I did notice I felt comfortable a driving an average speed of 28KPH.
The next trip I decided to leave it on PAS 5 and did 12 KM return on the same path and did notice a similar average speed while still not forcing myself
PS I am 73 years old and never biked the last 3 years due to hilly terrain in my new place. I need to do a 10+% grade to get away from the river area where i live
Move on to the next drive of 16KM return on the same path. I set the top speed to be at my average speed of 28KM and proceeded at the path on level 5 and gear 6 on the bike. I did notice that the bike wattage did drop down from 27.2 KPH to 29 KPH down to zero while no change on my effort. but faster i felt it so i kept at comfort level.
Now here is the observation for the next drive on the same hill but Furter up a steeper part of the hill and returning I just use the max speed to slow the bike down. the 3rd line on my battery showed up and stayed on the way up as I returned to approach the downhill about halfway the 4th battery light came back on. So, my assumption was to just not to use regen at all from now on. The meter does not mark the watts and stays at zero. but the lines 4 and 3 kept showing up during my trip through the hilly terrain that I use to drive before at 28KPH.
Here I am at today's drive and trying to bring my battery to low level I did notice a very important thing. First, I left with 2 lines on the battery and took off for another hill, this time at least 20% grade and it took everything I had to keep 15KPH on the way up on gear 5 and only 434Watts on the motor. as I traveled up until I saw one line on the battery and turned around and came back. it was rainy and I was scared of freezing rain I came back down the hill at 28KPH held back by the bike and regen. .At the bottom about 500Meter from home I noticed the 3 bars again and as the watts went to 434 again it disappeared to 2 bars again. So I assumed I did that hard trip without using much of battery power.
Then again today I left for a second drive up the last hill and observed max power was 293 watts going up the hill and I had to use gear no2 to make it up at barely 8 KPH. so the battery was weaker then the pervious time. This time i went down the road again over the hill at 28KPH and turned around when the battery last line flashed. proceeded to return and kept 28KPH and just let the bike coast down the hill at set max speed and by the time I got down, I had 2 full battery lines on the battery and proceeded on to my house. I throttled only and noticed 334 watts on my gauge which was more then when I went up the hill. I still need to experiment but if this is true I feel the max speed has lots to do with saving battery on the RADCITY4 bike
