My BBS02 motor (500W, 48V) has intermittently not been delivering power to the crank, when it gets cold. The motor revs up high, but doesn't deliver power.
It was happening some at 20F, more at 10F. Then when I shift, so the shift sensor temporarily turns the power off, the motor may engage, or it stops engaging. This happens using both the throttle and pedal assist.
The motor only has about 750 miles on it. I accidentally disconnected and reconnected the display/programming cable while the battery was plugged in a couple times, so possibly this damaged something. But it doesn't have problems in warmer weather.
So what's going on? I have been using it at a low power level, maybe increasing the power would warm up the motor more and make it work better.
I took off the drive cover and saw it looked pretty dry - does it maybe just need more grease? I greased those gears, but haven't had the chance to test it in the cold yet. I've been using Mobil 28.
