Recently purchased my first ebike. It's a Rambo Roamer and have been having a problem with the pedal assist. When using the pedal assist I keep using power. It seams totally random. Doesn't make any difference what gear, what PAS setting i use, and it happens at different speeds. I'm pedalling along and then the power from the motor just seems to quit then come back on again a few seconds to a few minutes later. The thumb throttle works without problem and I never loose power to the display. I have been emailing the company and they have been trying to help but it is really slow emailing back and forth so I thought I would ask for suggestion here in hopes of getting the issue resolved so I can get a chance to use the bike before the snow gets too deep. The company's 1st suggestion was to unplug the electric break sensors. I did that and it made no difference. Then they suggested it may be a problem with the PAS magnet. I took the motor apart and checked the magnet and it is not broke or cracked anywhere that I can see, but there may be a small crack in the plastic its really hard to tell. other than that the outside corners of the magnet look a bit ruff. Any thoughts?
