pushkar
I’m gonna get it wrapped. Gimme till the weekend to figure it out.It's too bad with the Kindernay we're saddled with mismatched rotors.
OCD much?It's too bad with the Kindernay we're saddled with mismatched rotors.
Noooooooo! Cut it yourself.Sick build! Need to cut the steerer tube, way to many spacers.
You have no idea...OCD much?
With love![]()
Why you wanna see MY bike?Midnight bronze with 27.5X3.0 pics next please!
No mine! I got the same thingWhy you wanna see MY bike?![]()
I know silly. In fact I copied your color.No mine! I got the same thing
This is most of why I always use those little handlebar bags! Hides this completely.Sick build! Need to cut the steerer tube, way to many spacers.
I can’t wait to see what it looks like in the sun, should be amazing!I know silly. In fact I copied your color.
Before you wised me up I was going with the lighter bronze which turns out to look like darkish gold.
Front rotor is the upgraded MDR-P while the rear rotor is what comes with the Kindernay IGH, which is the only option. Thus my earlier comment re: mismatched rotors. However, functionally this works better despite the visual incongruence.I noticed the front brake disc to be upgraded and rear one downgraded, any reason for this?
@pushkar on the 27.5X3.0 inch frames, is it possible to fit a 26X3.8 tire on a 65mm wide rim? Would love to be able to have a plus tire bike and a semi fat tire without having to change the rear swing arm.
Nice! Now if the same combo would fit the Dorado Pro fork I’d be a happy camper.Diameter : close enough
- 1.5" on the diameter going from 27.5 to 26" tire.
+ 1.6" going from 3 to 3.8" tire
Width :
+ 0.4" (10mm)
The issue may be that the chain may rub against the tire when you get to the tallest rear sprocket (the 42T). If that is not too much of an issue, then this should work.
26", 27.5" and 29" Wheel Compatibility
Won’t work with the Dorado because it uses a 20mm axle. The Nextie Tri Spoke use a 15mm axle. Bummer.I believe Dorado pro can fit those https://hayesbicycle.com/products/dorado-pro
@Cuz Vinny - another reason it will not work is that the Dorado is 1-1/8 steerer tube, Hydra is 1.5 tapered..... (adapters??)Won’t work with the Dorado because it uses a 20mm axle. The Nextie Tri Spoke use a 15mm axle. Bummer.
