PCeBiker
No-Hands No-Pedaling No-Credentials
 - Canada
i stuck a flat head where the censor is and pulled it outwards the most i could like 1/3 a cm where i think the magnet connects to the peddle sensor to disable it..
The magnets are on a spinning wheel contained within your PAS sensor,..
The angled rubber teeth or pawls, rub around the axle shaft.
When you pedal forward, the teeth grab the axle and the wheel with the magnets spins inside the mechanism.
When you pedal backwards, the rubber teeth slip and the magnetic wheel doesn't spin.
You would need to pull the PAS sensor out far enough that the rubber teeth no longer contact the axle, and that most likely didn't happen with moving it a ⅓ of a cm.
Just cut the wire if it keeps powering up on you.
Removing the chain is WAY more extreme than cutting the wire.
If you're convinced that you Do Not need the PAS sensor, then just cut the wire.
Besides,.. you gotta do what you gotta do when the Zombie Apocalypse happens.
