remove that box as in jiggle it around or unplug?
Trashing a bike by cutting wires ... you do that in the movies when stuck in zombie land and you got to get away.
OK, what about this,..
It's stupid simple,..
Thanks for the suggestions , im going to the diy store tmrw and going to attempt to take out the crank and pull out the cadence sensor ring and super glue or tie the ring to the bottom of the bike since i never use it anyways , as per your original instructionsOr this,..
You can still buy wire coat hangers at Dollarama.
i have a problem amego infinite plus which is similar to the ncm moscow .. So if i walk my bike forward , the pedal also goes forward too meaning the pedal assist will kick in at the same time so im hoping to take out the chain tmrw and ride it full throttle without the chain..
im pretty sure my derailer or something is messed since i don't pedal i thought it'd be good to just remove the chain.. I want to disable pedal assist in-case i kick the pedal and have it throttle on me by accident , is there a way? thanks
Just set assist level to 0 on the lcd controller when you are walking the bikei have a problem amego infinite plus which is similar to the ncm moscow .. So if i walk my bike forward , the pedal also goes forward too meaning the pedal assist will kick in at the same time so im hoping to take out the chain tmrw and ride it full throttle without the chain..
This sounds like a simple mechanical problem that any local bicycle mechainic can fix. A gummed up freewheel stops freewheeling forward., so the pedals rotate with the bike as it rolls. Or its broken and seized
Forget all that stuff about kludging the electrics. Wrong problem.
Its a broken transmission. When something like that happens, its probably going to get worse ("freewheeling forward" comes to mind if a pawl sticks in the other position).The OP doesn't pedal or use PAS modes anyway.
Fixing the sticky freewheel can be an expensive time consuming PITA.
Reminds me of how, when the Ford Crown Victoria (aka taxicab or police cruiser) reaches 300,000 miles, that is the time to put a new piece of electrical tape over the 'check engine' light.Sometimes the yellow warning ⚠ light is just a suggestion.
It flashes if it's something serious.
Smart move it to fix the problem not cripple it further.
I hate it when working under a car in the cold when a wrench slips and you bust a knuckle getting greasy, salty dirt into it.The OP is more than willing to remove the chain to fix the bike to his satisfaction.
He doesn't pedal anyway and it's the PAS modes that are making his ebike dangerous.
He's a delivery person in Toronto. That's Canada equivalent of what's going on in NYC, including to some extent battery fires.
His ebike is a tool used perform his job.
If that tool is malfunctioning in a way that he never uses the tool, then why spend time and money, and take a day off work to go to a DIY workshop in -14°C weather to fix something that he doesn't use anyway?
Just delete the offending hardware.
I don't have that annoying PAS sensor hooked up either.
And I don't want it or miss it.
The only thing that is different for me is that I can still pedal my ebike if I run out of battery.
The OP won't be too far from home base if he has any disabling malfunction, and I doubt that he'd ever resort to pedaling if he were to run out of battery.
The only issue is that "technically" an ebike is supposed to have a chain to be legal, but he could just carry it with the bike to be legal. It only has to be with him.
Maybe in the summer when he's got some time off and the weather is nicer, he might feel like "taking it to the shop" and freeing up the freewheel? But until then, all he needs to do is turn his PAS mode to 0 when he wants to walk the bike.
I hope he read these last few posts instead of going to the DIY shop today to remove his PAS sensor.
Note the dirt and rust on the screws and crank bolt on his ebike,..
We here in Southern Ontario live in the great North East salt belt.
We spread salt on our roads by the TON.
Salt, sand, and salty slush gets everywhere and wrecks everything during the winter.
This is what my car looked like at one point a few years ago,..
View attachment 169903View attachment 169902View attachment 169901
Not only is dealing with rusty s*it difficult and absolutely disgusting, try working on it outside in the middle of winter when everything likes to breakdown.
It's not about bringing it up to manufacturers OEM standards, it's about just trying to keep the damn thing on the road without breaking the bank or freezing your fricken fingers off.
Don't forget about just simply turning your PAS mode to zero to walk the e-bike.
That should disable the PAS sensor too.
