You did. But when?Huh??
I said it is still under warranty. I simply asked if anyone else was having the same problem. I didn't ask for any other ideas here.
YesI had to lube the one on my Bosch as it would stick really bad. but my second bike no lube needed at all. is it abus lock on it?
lube the lock I use tried flow because it's what I have. made a big difference. even my folding abs lock needed lubed to work well.
spray it with some triflow or such, abus locks tend to need lubing.I have a Trek Powerfly 2019, and I am now having the same problem. I have to put the key in multiple times, and turn the key multiple times, before the battery will unlock from the frame.
I guess I'll have to take the bike to the shop - but what an annoyance.
My door lock works for 30 years; why can't ABUS make their bike locks last just as long?
Thanks for your suggestion.spray it with some triflow or such, abus locks tend to need lubing.
did you take the battery off and lube it from that direction? that's where it makes the biggest difference. I dont know I just use it because its in a spray can and really gets in there. all my abus looks need lube bike and battery all benefit from lube.Thanks for your suggestion.
I tried muc-off wet chain lube - didn't help.
Maybe I'll try again - but a bit more.
Do you think triflow should work better than chain lube?
No I haven't. That's a great suggestion! Thanks!! I am going to try triflow spray can on the inside.did you take the battery off and lube it from that direction? that's where it makes the biggest difference. I dont know I just use it because its in a spray can and really gets in there. all my abus looks need lube bike and battery all benefit from lube.
