Ravi Kempaiah
- Canada
- City
- Halifax
Source for balancing thing?
If the individual cells are well matched, the quality control is good and the underlying electronics is well designed then the cells in a battery pack don't go out of balance.
There are millions of electric car users who do charge their pack only to 80 or 90%. In fact some manufacturers like Chevy Volt don't even offer full capacity to the end user. If the pack had 18 kWhr, they only make the 15 or 16 kWhr usable and have very tight control over electronics.
If you have a pack from Bosch or Shimano or Yamaha, you have a decent BMS board that monitors temperature, state of charge/voltage very actively and maintains certain cohesiveness. The issue arises when you have a cheap BMS board from a no-name battery and on top of that you are drawing lot of power from the pack then the cells experience different stress levels and at that point balancing becomes key.
The quality of BMS is critical for the longevity of the pack. Even if you use the best practices, if the underlying cells and BMS are not good, then you have things to worry. It is one reason big companies like Trek, Giant, Specialzied etc use battery suppliers with UL certification. One wrong fire incident or recall, the whole enterprise can be brought down.
So, in short, buy something that is vetted and you have less things to worry.
