An unstealable bike?
Nirmala
The sharerooler seems like it would wear the tire like a training roller does. Being made out of polyurethane helps but I would have to see it to believe their statement that it does not wear the tire.
Yeah, it is hard to say now how well this will actually work. I intend to use the smallest version just on the steeper/longer hills around here to boost my range and avoid overheating the hub motor on my Magnum Ui5, so hopefully even if the roller does cause some tread wear, it won't matter at the rate I will be using it.
