Adjusting 2021 Nyon angle on a Superdelite?
amayers
I have a 2021 Superdelite with the newer style Nyon display. I've put 1800 miles on it with a more aggressive forward leaning posture, and figured I'd try mixing it up and see about a more upright posture. So I loosened bolt A, and removed B to tilt the bars back to what seems like a nice position. However now my Nyon is pointed at my stomach. I don't see any details on adjusting the Nyon's angle, but I do see pics of the Kiox being adjusted up like I'd like. Is it possible to adjust the Nyon angle independent of the handlebars? This pic of the Kiox is almost exactly the same stem angle that I was hoping to try.
Loosen everything up again, and then use a small flathead to pry the bottom edge of the display holder free. There are too little feet/hooks that you're trying to release, then it will be adjustable in a similar manner to the Kiox Cockpit.
Worked like a charm. I was just scared to pry somewhere without knowing where.
Does anyone know what the angle range is for this stem? I'd like to get it as close to vertical as possible.
It's going to be limited mostly by how long the brake lines are on your specific bike.
Thank you,
With this and prior answer I managed to get a near vertical angle of the cockpit and adjust the position if the Nyon display in relation to the stem.
