Pine_marten
- USA
Thinking about this. Just for comfort, not performance on challenging terrain. Will it fit my headset and will my disk brake work with it?
Probably should ask my LBS.......
Yes, Amazon is crummy with info often. Good to know about air/spring difference. I coud go with a shock absorbing stem instead but i would have to order a new quill as the one on my Trek is integrated with the stem.It's hard for me to decipher the lingo in the ad. Is that a spring fork or air fork? I only recommend air forks for great adjustability. Spring forks are barely better than a rigid fork.
Just for comfort, I would consider a suspension stem. I have on old Girvin Flexstem on my Trek, and it helps-- a little. The modern ones would help more! I think I also had to replace the quill-- or part of the stem, or something. It wasn't a cheap job.Yes, Amazon is crummy with info often. Good to know about air/spring difference. I coud go with a shock absorbing stem instead but i would have to order a new quill as the one on my Trek is integrated with the stem.
Agree, but to build on that I would say measure, measure, measure! Stem diameter will be a big deal, as will whether or not you top and bottom bearing are the same (straight) or different (tapered). I found the dimension from axle to the bottom of the crown (or whatever you call that "bridge" between each side) pretty important too. I ordered a 27.5" version for my 27.5 bike and found that my tire to fender clearance to be very marginal. Knowing that, I would have gone to the 29" version.What bike and fork do you currently have?.
If new fork is longer than existing it will change geometry of bike and handling. Measure distance from top of your existing fork to axle and compare with specs of Rockshock. Need length when fork is partially compressed with rider on it. See youtube videos on setting up mtb suspension.
